Kubota L4479 front mount snowblower with L4455A subframe / front hitch assembly. All brackets are included to install on a Kubota L40 or L60 series tractor. This unit will fit L3560 , L4060 , L4760, L5060 , L5460, L6060, L3240, L3540, L3940, L4240, L4740, L5040, L5240, and L5740. The unit will require the above tractor to have a mid PTO. If one is not currently installed it can be added to your tractor.
The unit has hydraulic lift, chute rotation, and deflector. The lift and rotation are controlled from your tractor's loader joystick or hydro remotes. The deflector is operated with the same hydro remote as the chute rotation, enabled by an electronic solenoid valve. The entire unit has been serviced (chain adjusted and lubed, gearbox fluids replaced, fresh paint inside the chute and blower housing, and fresh seals on the deflector cylinder. The unit is ready to be mounted on a machine and go to work. The unit is located in near Baltimore Maryland, but can be shipped.
