flushing and priming hydraulic system
zoombats
B8200, BX23S
Feb 2, 2019
38
10
penetanguishene ontario Canada
I recently swapped the hydraulics from my B8200 manual to a B8200 HST. The FEL is functioning fine and I am about to reassemble my Bradco 8LD back hoe. The backhoe has all new lines and is ready to be reassembled after having been in pieces for a couple of years now. I would like to no the procedure for flushing and priming the cylinders. I am on a remote island in Georgian Bay Ontario. Any advice would be greatly appreciated.
4,711
To flush the cylinders you would need to pump fresh fluid into them while collecting the old in a bucket. Why do you think that is needed?
They do not need to be "primed". Just hook them up and cycle them a couple times to evacuate any air.
zoombats
B8200, BX23S
Feb 2, 2019
38
10
Thanks Dan. I only wanted to try to flush them because they have sat around for a while covered with tarps but really left to the elements.. I just thought if I could pass some kerosene or something through as a preliminary flush it would be good. So if I hook everything up and just watch my level in the resevoir the whole system will eventual bleed the air through?
4,711
Yes. It wont hurt to flush the cylinders but UTTO would be my choice for flush.
