Fixing Glow Plug Indicator B7200
Marishal
B7200
Apr 20, 2017
12
U.K.
Hi
I've inadvertently shorted/blown the dashboard glow plug indicator on my B7200 and can't find a UK supplier for the part. I believe it's 25 amp
Part Numbers: 15531-65950, ELI80-0177. Is there a fix please ? Could I use 25amp fuse wire ?
7,010
You can bypass the glow plug indicator with any regular piece of wire as a temp fix, or simply one one side of the connections to the other.
You should be able to buy the indicator from, ebay, amazon, and a ton of others that have them.
If it's a matter of shipping, let me know and I'd be happy to pass it along. ;)
Marishal
B7200
Apr 20, 2017
12
U.K.
Thanks for your kind offer I will bypass with some fuse wire I have then set about eBay etc.
