All, long time forum stalker, first time poster.
Been having problems with my BX24 working fine then losing RPM, power, and then almost stalling. I would have to lower the throttle to continue to work. Early on it would magically fix itself for a while. Searching here it was clear it was a fuel delivery problem. Replaced fuel filters with no long term fix. Tried bleeding possible air from system with no fix. Fuel pump has good flow. Fuel tank venting is fine.
I had to accept is was something IN the tank plugging the intake. Got an endoscope but couldn't make out anything specific although I did see orange flakes of what looked like paint.
Drained tank and tried to blindly vacuum the crap out with no luck. Decided that there was a shape on top of the tank that I imagined was intended to be an inspection hole. So I took a knife to it like a jack-o-lantern.
As per the images. The tank had plenty of leaves and lots of paint flakes. The leaves I have decided were my kids not putting the cap back on and mowing under our oak trees. I have no clue how the orange paint flakes got in there.
I vacuumed all the crap out, taped the plug on (temporarily until I find the best solution), and put in a couple gallons of fuel, and mowed 1.5 acres without a hiccup.
Thanks all for being helpful over the years. I hope this helps!
