well fellas i have not posted in quite some time but i just finished a project i wanted to share with you. i am pretty excited about this one. i built a small lift in my garage that i can either use inside or out in the driveway, it will lift my b7100 (loader and all) up to where the bottom of the tires are a full 53" off the ground. so far it will lift the Kubota, an exmark 72" z turn mower that weighs in at 1550lbs, golf cart and even snowmobile. i built it this winter and it took some doing but got it done. it is 8' wide 10' long and 60" tall. i used an electric motor with 650 ft pounds of torque and had to put hydraulic motorcycle brakes on it to slow the drop on it.
