Fill-rite 12vdc pump experts needed: WTH?
FTG-05
Jul 21, 2013
296
138
TN
Let's see if you can spot the problem with the directions on this Fill-rite 1204H 12vdc wiring instructions:
Is that little bit of "black" supposed to be the black wire as shown in the diagram?
Here is what the Fill-rite Owner's Manual says about wiring for the 12vdc model (emphasis added):
DC Wring Instructions:
1. Remove pump’s electrical junction box cover and straighten the red and black wire.
2. Screw the furnished cable connector into 1/2" NPT conduit opening on the junction box.
3. Strip 3" of the outer covering from one end of the furnished electrical supply cable.* Be careful not to damage the black and red wire insulation.
4. Loosen cable connector nut and pass the stripped end of the furnished cable through the cable connector. Tighten the cable connector nut.
5. Strip 1/2" of the insulation from the ends of the red and black cable wires. Using the furnished wire nuts, connect the cable wires to the pump wires
matching the colors.
IMPORTANT: Be sure no bare wire is exposed.
6. Fold wires into junction box and replace, making sure the cover gasket is in place. Make sure all screws are seated so there is no space between the
frame and the junction box (see Step 6 diagram on Page 6).
*12 AWG cable not supplied with pump only models
I've e-mailed Fill-rite with no response as yet.
Thanks for any help!
8,661
Looks like someone got carried away with the red paint when painting the pump and didn't apply any masking to the black wire. Scrape a bit of the outside of the wire, the one with the black showing and see if the insulation is black underneath. Sure looks like it is based on your photos.
FTG-05
Jul 21, 2013
296
138
TN
After writing this out, I think you're exactly right. Note that the first instruction is to remove the junction box to get to the wires. These wires were both exposed and out when I unboxed the pump.
I'll take off the box tomorrow and confirm.
Thanks!
1,914
I think those two wires should not be sticking out of the connector that you will be putting the cord through.
