OK has anyone else have had problems with the legs releasing and not bending the snot out of the little bolts. Something is way out of adjustment on mine and I cant seem to see what it is. When the bucket is curled all the way down which allows you to release the legs, the leg on the left seems to be high enough to allow the bolt to clear the latch, however onthe right side the leg still needs to raise up about a half an inch so it can clear the hook in the leg. SO it is either twisted up, if thats the case then I take the blame, if not is there any adjustment any place to line things up ? I am at a real loss here
