FEL - LA1154 vs LA1154EC
bc1962
M7060HD ROPS / M4-071D / M6800 ROPS / RC2512 / ZD1211
Nov 23, 2015
21
Walnut Grove, AL
Does anyone know what the EC stands for, and or whats the difference between an LA1154 and the EC version?
Thanks,
Bill
8,770
I think (and could be dead wrong)it is the Easy Connect system, for the hydraulics lines that feed the loader, it's a cam locked block.
Note: EC on older tractors was the Ever Clutch designation. ;)
bc1962
Nov 23, 2015
21
Walnut Grove, AL
Thanks Wolfman. Sounds as reasonable as any other explanation. My reason for asking ... I was looking for a WSM that showed how to properly adjust the linkage on the boom/bucket control lever. I recently had a M7991 3rd function valve installed and the control lever is a little more "sloppy" than it was before. Anyway, I found a .pdf for the WSM on the LA1154EC. I will try emailing Kubota ... should be interesting ... if I get an answer at all.
Thank again!
