F2560E Rear Ballast Weight
jsswain
F2560E B7100 B7001
Apr 20, 2016
Saskatchewan, Canada
I recently purchased a used F2560E to mow grass on my acreage. The machine came with a High Lift Grass Catcher and a 72 inch mower deck. Some of the grass I mow is on ditch slopes. I had no need for the high lift grass catcher and I felt it made the machine top heavy so I removed it. The F2560E comes from the factory with a large ballast weight on the rear of the machine however this weight is not present on my machine. It had to be removed by the factory to install the drive for the grass catcher. I now need to add rear ballast weight but I have no idea how much to add. Has anyone had this same problem and if so, what is the amount of weight you added. I suppose the alternative is to try to determine the total weight of a high lift grass catcher model GC-F30H and add that amount but I have no idea what the figure is?- Anyone with any assistance for me?- Thanks
