f2100 help
boatruptcy
Bend, OR
does anyone know how to drain the hydraulic fluid on this mower, i have looked online and found the exploded diagram of it, and it shows the filter on top like i have, but cant figure out how to drain. i am thinking it is on the right side of the machine where return line from the cooler feeds in what looks like a long bolt, it is called filter oil in the parts description. it appears to have a screen on a long bolt, does this sound right? thanks in advance
eserv
BX24, A1000 Kubota Generator
May 27, 2009
2,140
139
Hardisty, Alberta
You can drain it from that fitting, and you should remove it and check it for contaminants, But the proper drain is right on the bottom, directly under the seat AND a small plug at the bottom of the final drives (both sides) on the outside.
