Exhaust pipe surface rust
bambam31
L3800HST 4x4,R1,FEL, 6'disc, 5'bush hog,piranhaTB,6'grader,6'rake, 48"forks
Apr 3, 2014
320
26
23
Mobile, AL
I took a look under the hood today and was surprised to see this corrosion. Is this normal? My tractor is almost five years old. I keep it outside under two covers so it doesn't get rained on. What can I do to stop or slow it down? I'm sure it gets hot under there. Thanks.
redmaher
253
US
Re: Engine corrosion
Is that part of the exhaust? If so that's normal.
Sent from my LG-H872 using Tapatalk
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,440
78
Rocky Face, Georgia
That looks normal on the exhaust.
When you say under cover, does that mean covered with a tarp?
My brother tried that and it would actually hold moisture then after a few days in the heat it would dry back out. We figured it was doing more damage than good. Cheap lean to carport was his solution.
motorhead
2009 B3200, 2007 Dodge/Cummins powered Ram 2500 395hp
May 17, 2012
441
34
Atascadero
When you cover something, especially over dirt or gravel, you seal in any moisture that comes up from the ground. If you have to park on dirt or gravel and you want to cover the machine, put a piece of thick black plastic down to park the tractor on and make sure it is set up so it doesn't collect rain water and trap it.
