As the cold winter season draws to a close and the green of spring emerges, your tractor must be prepared to tackle upcoming spring cleaning. A well-maintained tractor ensures efficient and effective spring work.
1. Start with a Thorough Inspection
As winter wraps up, give your tractor a complete check-up. Look for wear and tear, especially on the hydraulic systems which are crucial to operate smoothly. Replace any hoses that show signs of cracks or leaks. Inspect the couplers and fittings for corrosion or damage. Prevent unexpected breakdowns during critical times of use.
2. Change the Oil and Filter
Replace the oil and filter to allow the tractor to operate smoothly. Fresh oil keeps your engine and hydraulic systems lubricated and functioning at their best. After your oil is replaced, check other fluids, such as the coolant and hydraulic fluid. Keep these fluids at the correct levels as they can degrade over the winter.
3. Check the Battery
Cold weather can take a toll on batteries, so make sure yours is ready. Test the battery, see if it holds a charge and inspect the terminals for corrosion. Clean them if necessary and tighten any loose connections. Batteries that are several years old might just need replaced to avoid unexpected failures. You do not want to be dead in the water when there is time-sensitive work to be done.
4. Inspect Tires and Wheels
For your safety and tractor efficiency, maintain your tractor’s tires and wheels. Check tire pressure and adjust it according to the manufacturer’s recommendations. Replace any tires showing signs of wear or tear. Also, make sure the wheels are securely fastened and the rims are in good condition.
5. Grease Moving Parts
Lubrication is key to a long-lasting, efficient tractor. Grease all moving parts, including PTO shafts, bearings, and joints, to help the machine operate smoothly and to prevent rust and wear. Repeating this step will significantly extend the life of these components.
6. Prepare Hydraulic Systems
Hydraulic systems are the backbone of many tractor operations. Ensure the system is leak-free. Check the hydraulic hoses and pumps for wear or damage. A well-maintained hydraulic system translates to efficient power transmission for various implements.
7. Test All Functions
Once maintenance is complete, test all the tractor’s functions. Operate the hydraulic lifts, PTO, and any other mechanical systems to check for smooth operation. Test your new Summit Hydraulics kit and hydraulic attachment for proper installation. Address any issues you discover before they become major problems and reach out to us as needed.
Conclusion
Prepare your tractor for warmer weather to ensure a productive and hassle-free season. Follow our tips and you can look forward to successful planting, tilling, and harvesting. Regular maintenance extends the tractor’s life but also ensures operational readiness. Happy farming!
Ensure Your Tractor is Ready for Spring
summit-hydraulics.com
