engine will not shut off
Stuart Dancer
l3710d
Jan 28, 2017
pioneer calif u.s.a.
tactor starts fine turn key off engine continues to run must use emergency pull button to stop engine// replaced the solinoid for fuel not prob. Any help ouut there have purchased the timer relay but not installed thanks stu :eek:
clay45
L2050DT, TSC 5ft Rake, Tartar 5ft rototiller, TSC Middlebuster, TSC CarryAll
Feb 6, 2015
279
SC
That sounds like how its supposed to be.
bxray
Bx25d
Dec 1, 2014
712
Cleveland, ohio
Check all the connections and fuses.
Does the timer get power when you tern on the key?
Does the solenoid get power when you turn off the key?
When you turn on the key it arms the timer and when the key is turned off the timer relay fires the solenoid.
Ray
Stuart Dancer
l3710d
Jan 28, 2017
Check the stop fuse under the hood. ;)
found the fuse and plug both corroded cleaned works great//also L3710 manuel injectors malfunction ?reason new fuel has not enough lube in fuel causing injectors to not move freely ///Add 5 oz.transmission fluid to gas tank when filling this will lube injectors works great no more put-put from engine/Now full powerThanks for all helpful suggestions/Stu
