Engine will not crank
Jhgr
L. 3901
Aug 14, 2018
23
Cumming Ga.
I have a l 3901 and when you turn the key to crank it does nothing you can hear something that sounds like he fuel pump but nothing else. The battery is good I put jumper cables on it still same, check seat switch, power take off , fuses and hydrostatic peddle nothing helps. Does anyone have a suggestion.
Thanks
Harold
armylifer
Mar 26, 2013
2,041
780
Thurston County, WA
Check for corrosion on the battery cables at both ends. Also check for tightness of the cables.
Jhgr
L. 3901
Aug 14, 2018
23
Cumming Ga.
I already did that nothing changed. It did the same thing last week and i turned the switch off and back on and it started.
2,543
Based on what you are saying.....
It is still a safety switch that is not setting correctly.....
OR perhaps a faulty key switch (I doubt it:))
Or a starter problem (I doubt it too:))
Holleyman
Kubota B6001, Caterpillar 252B, AM General M813A1, Ford 8N, Komatsu PC30
Sep 25, 2013
70
80 acres in Athabasca AB
Volt meter the main cable at the starter looking for battery voltage. Then try cranking the starter looking for the solenoid crank wire looking for voltage (usually no less than 1 volt less than battery voltage). If both are good, check to make sure the starter is tight or if equipped a ground strap is tight and in place. If all of that is okay then the starter is the culprit.
3,297
I am inclined to go along with a safety switch,, maybe the PTO switch or seat switch
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,235
1,017
Williamstown Ontario Canada
I have a WSM which covers the L3901.
In the WSM is a chart for the "No Crank," condition.
On the far right of the chart are page references which walk you through each of the suggested diagnostic steps.
If you would like a copy of the WSM, send me a PM and include your email address.
If you need help performing the WSM suggested tests, I will help you through it.
All I ask is that you have or get a $10 12 volt test light.
Dave
Jhgr
L. 3901
Aug 14, 2018
23
Cumming Ga.
What I have found is if you wiggle the forward and reverse pedal it will crack most of the time. Trying to see how to adjust it.
Thanks for all your help.
2,543
That safety switch can be a PITA sometimes:) There is an adjustment - sometimes it will involve a position control that pulls it back to the "neutral" middle position.
Fender5803
L3901 LA525 BH77; LP 1860 rotory cutter; LP 1060 grapple; forks & bucket
Aug 9, 2015
37
Henniker, NH
I have to do this on my L3901 too. Give it a good shaking.
I'm going to ask dealer when it goes for it's 400 hour service very soon.
Jhgr
L. 3901
Aug 14, 2018
23
Cumming Ga.
The problem was forward and reverse safety switch. New switch and everything is good now
4,451
Thanks
Harold
I will add PTO safety switch to the list its given me no crank on my L3901 several times..
