Engine RPM's
Ryeder
B2650 hsd
Feb 10, 2022
NH
Have an issue I can't figure out. And the answer is probably simple or so I hope.
2018 B2650.
I raise the bucket high and the engine's RPMs lowers. I drop the bucket and the RPMs return to normal. Any ideas?
Mitjam
Jan 14, 2013
319
370
Edmonton, Alberta, Canada
2018 B2650.
Sounds like normal operation to me. When your lifting the loader it’s drawing from your hydraulic pump which in turn will put load on your engine especially at lower rpms. If your at end of the rams stroke or full lift there is no where to fluid to go it’s dead heading and you will really notice it then. When you lower it under its own weight the fluid is returning to sump or back to tractor. Which doesn’t require any power. Hope this helps or what you were asking for
Nicksacco
Kubota L35 TLB, 2014 RTV-1140CPX
Sep 15, 2021
698
412
Bahama, NC
When raising the bucket (loader??) it would be normal to have an rpm drop that recovers when lowered. Especially if your starting at a very low rpm. The pump would drag the engine down a bit.
But from your description not clear of all the details.
Ryeder
B2650 hsd
Feb 10, 2022
NH
Thanks... normal is good.
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
749
651
E.
2018 B2650.
How much weight is in your bucket and what are the starting rpms?
If you are lifting significant weight and starting at lower rpms then this may be normal as your are lugging the engine if change deemed significant.
But if experiencing this with little or no weight and significant rpm you might be experiencing a problem like something bent or binding.
More info needed imo. Including where in the stroke cycle. You are in.
Ryeder
B2650 hsd
Feb 10, 2022
NH
Bucket weight has little difference with the RPMs lowering. As far stroke position, RPMs reduce about 2/3 of maximum.
Ryeder
B2650 hsd
Feb 10, 2022
NH
perfectly normal though if you want to 'cure' it , add feedback from the loader to control engine speed.
If it's a normal operation, no need to fix it. Guess I never noticed it until recently. Maybe I need to pay attention more...thanks...
6869704x4
L45TLB, 49 8N, 57 641, RTV-X1120D, Z422
Jun 29, 2011
364
514
SE, NM
Funny, my RPM drops more when I lower the bucket than when I raise it.
