Engine error P0606
richhelle
L4060
Feb 8, 2026
Brookline, NH
My L4060 had a flashing warning reported P0606. Flashing triangle goes out after restart, but error code is still there. Chappell Tractor Maintenance guy says it indicates water in engine. I cleaned out the sediment bowl and oil shows no milky color
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
922
893
E.
I would disagree and if me would put in a new battery and clean all battery cables including frame grounds. Educated guess from experience only would be a low voltage reading at the computer
whitetiger
Nov 20, 2011
3,365
1,803
Kansas City, KS
Kubota TSB-2023-35-E-R3:
If only DTC (Diagnostic Trouble Code) P0606 is present, update the ECU Software to the latest software and clear the code. This can only be performed by a dealer using KOBD ACE.
This is covered for 8 Years from the retail date by Kubota.
