Engine Dies
jlcardwell
Kubota B2150HST
Sep 28, 2020
Illinois
I have a 1992 kubota B2150HS and it dies immediately after starting it. What would cause this to happen? Also it creeps forward or backwards without any pressure on the foot accelerator pad. What would cause this to happen?
6,394
Starting and it stopping when you let off the key is stop solenoid or stop solenoid timer issue.
Creeping forwards or backwards is a mechanical linkage issue, it's more than likely an issue with the neutral holder.
TECH101
Kubota - Bobcat - Caterpillar - Case - John Deere - FARM - CONSTRUCTION -
Mar 8, 2022
69
15
By the sounds of it most likely your neutral switch
Pedal adjustment should fix both issues
TECH101
Mar 8, 2022
69
15
The B2150 does not have an HST neutral switch.
Too many models to remember everything next time I will verify through the WSM before making any suggestions
I have had issues with the timer before but from what I remember it would not crank at all. I could be wrong I work on too many machines to remember everything
