Both my oil pressure light and heat gauge quit at the same time. These are both on the same fused circuit so I figured it had to be in that circuit somewhere. I eliminated the key switch as a problem. To eliminate the fuse block as a problem I jumpered it and the oil light still did not go on, but when I put a grounded test light on the jumper the oil light did go on!
Any suggestions??? thanks, Mark
