EGT Gauge, worth it?
drewscruis
B7100D with FEL and tiller
Sep 9, 2011
21
Eden, NY. usa
doing an overhaul on my b7100 and adding a few gauges, (tach, oil,volt,temp) and was wondering if an EGT gauge would be worth the effort, there pretty reasonable. I know there mainly used for turbo engines (this isn't) but any additional info while operating the tractor to prevent catastrophic failures is always A good thing, just want to know if i'd be wasting my time and money.
kuboman
721
Interesting maybe, worth it...not really.
One rule of thumb with a non turboed engine is if there is black smoke the exhaust temp is up in the red zone.:D
Kubota Newbie
M4500, New Idea Cut-Ditioner, JD 14T Baler, IH "Plow Chief" plows, Oliver Rake
Dec 28, 2010
533
81
Mount Vernon, Ohio
Not worth it. Doesn't tell you anything useful unless you have dyno tested numbers to compare against. Even then......
Kytim
Aug 14, 2009
848
15
Western Ky
As a side note, how are you mounting the gauges? There's not a lot of real estate on the dash tin. I'm looking for a neat way to add some myself. I just hadn't Decided how yet.
drewscruis
Sep 9, 2011
21
Eden, NY. usa
I've played around with the lil bracket that came with the gauges but everywhere I mocked it up it looked like crap, so I need to make a run to the steel store and I am going to make a lil gauge pod and mold it into the hood like the late 60's muscle cars had back in the day, just waiting for the weather to break so I don't freeze my behind off when I'm making it. I'll post some pic's of it when I make it up. as for the tach, I just used the factory location for the hr meter and picked up a mechanical tach that fit in the hole that has an hr meter built in.
