Dynamo on a B2150
kmmontandon
B2150
Feb 1, 2019
10
Chester, CA
Is the rotor supposed to spin by hand without much effort?
My dynamo recently seized up, so I decided to just replace all the bearings myself. When I took it off, it wouldn't turn at all. I put it all back together with the new bearings, and now ... the rotor is very hard to spin by hand. I'd never done so before, so I don't know what it's supposed to feel like. I don't want to put it back on and have it seize and burn up the belt.
10,805
Yes it should spin and you will feel the pull of the magnets, the spin will be pulses not a free spin.
3,043
As Wolfman said - you will get a bump - then smooth then a bump.
AS you send the armature through the permanent magnet - the attraction will make a friction point then as it moves a bit more the friction will go away.
In simple terms - the friction is an electrical build up !
If you want to - get the appropriate socket - add it to a cordless drill, hook up the leads to a volt-ohm meter with IT SET to AC ....... and spin it fast!!!! You should read something close to 30 volts AC!!!
