Dynamo 2 wires connection
paulmoni
Kubota B500E
Sep 16, 2016
Australia
Hi Guys,
I've seen this topic but the answer I'm looking for still is not answered. My B5000E Dynamo had 3 wires, I have now replaced this with a new one which has 2 wires.
Do these 2 wires goto the rectifier?
2,600
Hi Guys,
Yes, they will have to go to the rectifier to be converted to DC.
What happened to the old dyno? It quit ? Bearings?
How did it hook to rectifier? Got any pictures?
paulmoni
Kubota B500E
Sep 16, 2016
Australia
The windings in the dynamo were touching the body as the ceramic deteriorated. The old dynamo has white, brown and yellow. The new dynamo has both blue. I believe I connect one dynamo wire to the rectifier and the either also goes to the rectifier and bypass the light switch altogether as I don't use these now.
I should post some pics when I get the chance.
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,243
1,026
Williamstown Ontario Canada
I remember studying the previous thread including the wiring diagram.
I believe the headlights and perhaps other lights are powered by unrectified alternating current coming from the dynamo. The third wire went directly to the headlight switch
The dynamo produces alternating current in 3 phases. Two phases are sent to the rectifier to charge the battery which can only accept direct current.
Rectifying AC to DC has losses associated with the process in the form of heat and so in the interest of best efficiency not rectifying one phase and using it for the headlights was an efficient design.
The light bulbs are simple resistors which glow when hot producing light and dont care if they receive AC or DC.
I expect the designers of the electrical system planned the size and type of light bulbs to absorb the full output of the unrectified single leg or phase of the dynamo.
Probably the brightness of the headlights changed with engine speed.
If you dont need the headlights then do nothing with the third phase or wire.
If you do then try and find a rectifier which will convert all three phases to DC and connect the headlight switch through a fuse to the battery.
Plse post external views of the old and new dynamo together with any name plate info on them to be certain my comments are correct
Hope this makes sense.
Dave M7040
