Dump trailers.
lilguy
166
11
Illinois
I need a dump trailer for use on my 16 acres. Local dealers only carry large highway models. Anyone have experience with smaller CUT/ATV type dump trailers.
Will be pulling it with either B8200 hst or a B2601
2,543
5,528
A two ton trailer will be a tad too big to pull with a B8200!! Especially if you would happen to put something in the trailer.
GaryL
2003 BX2200 - loader, mower, blower, grss collection system
Nov 22, 2014
119
Holden, MA
I bought a 5x8, 5000 lb, 3680 lb payload Cam Superline Dump trailer. I use it for hauling to the dump and mulch, etc.. Loaded and empty, I pull it no problem with my BX2200 around the property.
Grouse Feathers
Feb 16, 2015
1,022
10
Lovells, Mi
Like GaryL I bought a 5x8 dump trailer. Mine is a Sure Trac 5000 lbs, 3480 payload. The smaller dump trailers have less capacity but with a single axle are a lot more maneuverable around the yard (and a lot less damaging to the grass then turning a tandem axle). It is easy to move empty with my BX2370, but I always position it so I can hook it up when fully loaded to my truck. Fully loaded would probably be to much weight for the rear of the tractor.
