Draining Overfilled L2501 Hydro Fluid
Chuckster5
Kubota L2501
Apr 9, 2019
Montgomery, Alabama USA
My first post in this or any forum. I see a lot of discussion about overfilling L2501 (or similar) tractors with the sight windows.
My question is since I have overfilled this, how do you drain a little to recheck it?
My dealer said loosen the hydro filter.
Is this right?
SidecarFlip
Banned
561
That or the drain plug (carefully) and use a clean catch pan as the fluid is useable again. (so long as you drain it into a clean container.
SidecarFlip
Banned
561
In reality, if it's just a tad overfilled, it won't hurt anything. If you 'filled it up' it might.
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
76
Rocky Face, Georgia
You need to be sitting on very level ground to check. My experience with the site glass is that just a small amount of lean in any direction will through the fluid level high or low.
Bulldog
Mar 30, 2010
5,434
76
Rocky Face, Georgia
And if it was me I wouldn't loosen the filter to drain. You stand a chance of messing up the seal then the filter is useless.
Blondie70
L2501DT('18)L2501('15)
Aug 6, 2016
267
Poplarville, MS
A super easy way to do it is to remove the sight glass. Probably unscrew by hand. It's a plastic screw in that is easy to take out. Have a big wide pan to catch the fluid. If you park the tractor with a right hand lean, you will probably have the level just right when it drains down to the bottom of the hole.
Good Luck.:D
