Discovered something while mowing.
John D 2
B2601 LA435 loader, 54inch MMM, carry all, boom pole, fertilizer spreader.
Jun 6, 2023
166
172
My property is about 1.5 acres. I use my B2601 with the 54 inch MMM as my lawn mower.
Today I decided to try mowing with the engine rpm at 2400 instead of the 2800 rpms (540 pto rpms)
I discovered that it mows the Johnson grass a lot better. At 2800 rpms it would miss some of the stalks causing me to have to go over it a second time. At 2400 rpms it cuts everything clean and leaves no stalks to re cut.
The only explanation I can think of is at 2800 rpms the air flow caused by spinning blades keeps some of the stalks pushed down until I pass over them. At 2400 rpms it doesn't have as much air flow and cuts them clean.
Blades are the original ones that came with the tractor.
Less noise, less fuel, and a better cut. Winning!!!
