Digging a pond
6,926
Not a pool / pond, but other large, deep holes, one problem with doing it with a FEL is the speed of work is very slow and the ramp needed to get to the bottom is extremely long. ;)
helomech
527
East Texas
The main problem comes is that you have to have a way in and out. This is fine on the side of a hill, but if no hill, you will need a long slope in and out. That is a MX-5100 in the hole. The hole was enlarged after this pic to 30X100
BAP
Dec 31, 2012
2,800
906
Lots of cellar holes and ponds used to be dug by bulldozers and front end loaders on tractors long before backhoes and excavators were invented. Everyone nowadays thinks that everything has to be done with an excavator or else it can't be done. In reality, the reason people think that is they have no idea how to properly operate other equipment to get the job done.
William1
BX25D
Jul 28, 2015
1,131
321
Richmond, Virginia
A dozer works just fine, if the excavated material is going to remain in the vicinity and you are doing a pond with somewhat sloped banks. My dad had a one acre pond done in a one weeks time by a single guy on a big dozer. The materiel was moved to a step nearby hill and lessened the slope.
A dozer is not the tool for digging a square hole.
A dozer will not get the material in a truck to haul away.
I'd never try and use a FEL for that.
When the time comes to fully dredge my pond, we will drain it, dry it and use a dozer then a large excavator to fill dump trucks to move the material 1,000 feet away. At least that is the current plan. Last fall, I (with the help of gracious neighbors) dredged out an area (about a 100' circle, 3' deep) where silt from the stream that fills the pond had built up. We used a mini excavator and a dump trailed pulled by a tractor. It took ~60 loads at ~four yards a load and two days. I used my FEL six months later to level out all the dump loads. It excelled at that job.
