Rosohatica
Kubota L3200, Tehnos MULS 130 flail mower, Fužinar 14” plow, Landforce 5′ tiller
Hi all,
Some of you may have read my earlier post about working in very muddy conditions. If not, it’s here for context:
https://www.orangetractortalks.com/...o-to-or-on-your-kubota-today.6326/post-823323
Today I tried to engage the differential lock, and the pedal goes down very easily with almost no resistance. That immediately raised a concern, so I reviewed the correct operating procedure for the diff lock. Unfortunately, I realized that on that muddy day I engaged it completely against recommendations—while the wheels were already spinning, likely with one wheel spinning freely in the mud while the other was not.
Based on what I’ve since read, engaging the differential lock under those conditions can cause the differential lock pins (or dogs) to break, which would explain the lack of resistance at the pedal. I’ve also found that this type of failure seems relatively common on the BX series, with several videos documenting it, for example:
From what I can tell, the BX differential uses four pins. My questions are:
Thanks in advance for any insight.
- How many differential lock pins does the L series use (specifically the L3200)?
- How common is this type of failure on the L series ?
- What is the easiest or least invasive way to confirm whether the pins are broken?
- If this is indeed the case, should I stop operating the tractor entirely until it is repaired?
