Diesel Mowers
garebel
Flowery branch, ga usa
Had opportunity to acquire several diesel mowers. Good condition but need some minor repairs. Seems parts availability is mostly through Kubota dealers. Does anyone know of aftermarket parts availability?
6,905
There are aftermarket part all over the internet, but where you purchase items that are critical to proper function and not a source of constant repair/replacement is most often the dealer.
Give us an idea of what you're needing, and the age of the machine. Someone will have an idea.
2,864
As Cat said - we need specifics,
In your case - what is the model of engine, which might not be easy to find - unless that application used only one type, there are numbers on the block and head near the injection pump.
2 cyl, 3 cyl or 4 cyl?
Pictures would help too;)
motorhead
2009 B3200, 2007 Dodge/Cummins powered Ram 2500 395hp
May 17, 2012
441
42
Atascadero
If they are all the same brand and model, you might to choose to cannibalize one of them for spare parts.
SDT
multiple and various
Apr 15, 2018
3,312
1,102
SE, IN
Aside from generic parts, e.g., filters, blades, belts, etc., most Kubota parts are not available from aftermarket sources.
SDT
