Dashboard not working
Scooter70$
Kubota L3130
Jul 23, 2023
Alabama
My dashboard on my Kubota L3130 is not working. All digital parts and tachometer. Have already tried the display button and that did not correct. Any help is appreciated.
1,415
Look at the fuses and see if there is anything wrong with the fuses. Probably one is blown.
Will the tractor crank or headlights or flashers work at all?
Clean all four connections on the battery cables and the two battery posts.
Scooter70$
Kubota L3130
Jul 23, 2023
Alabama
Headlights work, dash illumination works, all fuses are good. I’m reading on other threads that it is possibly the alternator and it does have trouble with the battery staying charged.
1,415
Okay thanks for the information.
I think I would still start by cleaning the battery cable ends just since it is easy and doesn’t cost any money, just time. Often the connection between the frame and negative cable is bad.
Then I would leave the negative cable off the battery and fig out how to remove the dash and then clean the cable connections to the dash. I have seen some posts on here saying that the wire connectors or the pins on the dashboard are corroded. I would start off with electrical contact cleaner and see if that works. (Don’t forget to attach the negative cable before trying anything.
While the dash is off see if you can get to the back of the switch and clean it up also.
Good luck
4,908
curious, does the tractor start and run normally ?
if it's only the dashboard really doubt it's he alternator.
According to the WSM, there's 2 multipronged connectors. It is possible a corroded wire/bad pin in one of the 2 connectors is the fault.
Scooter70$
Kubota L3130
Jul 23, 2023
Alabama
Good luck
Thanks! I will.
Scooter70$
Kubota L3130
Jul 23, 2023
Alabama
Thank you! Will check that too.
#40Fan
291
167
Leave the charger on the battery after you have started. That will deteremine if it is a low power issue, which I doubt.
