Damn! I feel like a newby.
Hoserman
Kubota BX2380 Land Pride Box Blade
Aug 1, 2022
210
339
Grayling, MI.
Two days ago, was the first time I removed the FEL from my new BX2380. I have done this numerous times with my old 2380. Where I park it is under an overhang on my shed. There is a concrete floor there, so level is not an issue. Position IS! Took it off no problem. Mowed the lawn and it came time to put the FEL back on to remove yard waste. Pulled up to it, connected the hydraulics and commenced to work it back in the cradles. For whatever reason it got cocked, fell off the slab on the other end, and that's where the fun began. I finally had to get my floor jack and lift the bucket up high enough to get cribbing under it to where I could re-install it on the tractor. For a while I had more rigging on it than pulling a D-8 Cat out of a swamp. 😜😆
Reactions: 8 users
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,791
2,227
Western MT
As long as you got it back working, that's all that matters.
imnukensc
BX2380
Sep 10, 2015
769
729
Midlands of SC
I've taken the FEL off and put it back on several times on my 2380. It's a PITA to put back on compared to the 2370 I had. Wish Kubota had never changed the FEL mounting from what the 2370 had. Would've kept the 2370, but hated the digital dash because I could barely see it in bright sunlight or when it got dusty.
Flintknapper
L2350DT
May 3, 2022
2,017
2,560
Deep East Texas
T For whatever reason it got cocked, fell off the slab on the other end, and that's where the fun began. I finally had to get my floor jack and lift the bucket up high enough to get cribbing under it to where I could re-install it on the tractor. For a while I had more rigging on it than pulling a D-8 Cat out of a swamp. 😜😆
:oops:
Truly sorry to hear of your misfortune, but at the same time....it 'warms the cockles of my heart' knowing I am not the ONLY one this kind of thing happens to.
Thanks for sharing your story.
Hoserman
Aug 1, 2022
210
339
Grayling, MI.
OOOOOOOO I'm glad I didn't know what the 2370 was like if that is the case. This beast cost me a couple hours of head scratching. But it won't happen a second time.
4,695
Yup you can do it a hundred times and never have a hitch and on the 101th time, it is a nightmare!
Hoserman
Aug 1, 2022
210
339
Grayling, MI.
I guess this is a human thing right. I've been told, if your not making a mistake you're doing it wrong. 😜 😆
10,041
You all would have a full blow fit if you had to deal with taking the loader off in sand like I do!
yorkies77
Kubota BX23S
Jun 7, 2020
Idaho
I took mine off a few years ago while we were building out home. I took it off on a piece of plywood and it sat there all winter. When I tried to reinstall it it had sunk 8 inches on one side and the tractor also sank in the mud. I tried to get it on for 2 days and could not get it on. I called the dealer and they had one of their owners stop by when he was delivering a tractor. It took both of us about 2 hours but we finally got it reinstalled. What a disaster, not fun. I now take it off on a cement pad. It only takes a minute to take it off and reinstall it.
BBFarmer
Jul 12, 2024
789
1,621
Terry, MS
Had that happen to me a while back for the first time. Bucket fell forward off the pad. 45 minutes later and a soaked shirt we were back in the game. Absolutely terrible.
Glad you got it though.
BAP
Dec 31, 2012
3,093
1,228
Take mine off and on all the time on a mostly level, sort of firm, gravel pad. Sometimes it takes a little wiggling around, but have never spent more than 5 minutes putting it back on and I probably take it off and on 20-25 times a year.
