D950 fueling issue
Pete G
Catalina 34TR with a Kubota D950 engine (M-25XP Westerbeke)
Jan 28, 2025
Cleveland, OH
Hi all,
I have a sailboat with a Universal Westerbeke MX-25. It's also the Kubota D950, just stuck in a sailboat instead of a tractor. I am having a fueling issue. I'm getting fuel from the low-pressure fuel pump, but the high pressure pump isn't sending fuel to the fuel rail. I replaced the bleed valve (was broken) and I can get fuel flow to the by pass line.
My assumption was that the high pressure pump needed to be rebuilt. I replaced it with a rebuilt unit, but I'm still not getting fuel through the fuel injectors feeds. I bled the engine at the fuel filter - boat folks indicated that it was air trapped in the fueling system, but still didn't run. I replaced the batteries, and it turns over easily, but won't fire up.
Suggestions, nearby mechanics both appreciated.
Pete in Cleveland
7,158
When you replaced the pump did you reuse all the shims under the old pump?
Those shims set timing.
When you reinstalled the pump did you make sure to align the rack pin with the governor slot?
You will not normally get fuel to flow out the bypass off the injectors on these engines.
I would first remove the injector lines from the pump and the injectors.
Set throttle to high, crank the engine, you should get 2 to 3 inch fountains of fuel out of the delivery valves.
If that is good, then reinstall the injector lines, but leave them loose on the injector side and crank again till you you get good fuel in little spurts without bubbles, tighten and it should run.
Pete G
Jan 28, 2025
Cleveland, OH
I did not remove the shims from the old pump, at least to my knowledge. It's on the back floor of my wife's car, so I'll check this evening. There was really no way to not align in the slot.
I'll start with removing the lines. When I swapped out the pump, I did remove the lines and blow air through them.
The boat is in a yard on Lake Erie (outdoors), so getting to it this weekend will depend on the weather.
Pete
7,158
Pete
In the back seat of the wife's car! o_O If i did that to my wife's car she would kill me!
If you didn't install the shims with the new pump, it is imperative that you do that first, as that is critical for it to run.
When you install the pump you need to pull the stop lever cover off the side to align the pump rack pin to the governor slot.
Pete G
Jan 28, 2025
Cleveland, OH
Thanks. I didn't remove the side panel for the installation - just slid the new pump in. I'll start with tearing it down and removing the pump, etc.
1,505
There may be an air bleeding valve on the injector pump. It may look like a bolt screwed into a hew fitting where the fuel line is connected. I really helps on my engine (not same as yours) since it gets air out of the fuel line and fuel filter on my tractor which is gravity fed to the injection pump.
Pete G
Jan 28, 2025
Cleveland, OH
There is. When I attempted to open it, it snapped off. I replaced it, so it's functioning now, and I can get fuel flow to both sides of the bleed valve.
7,158
D650,D750,D850,D950, V1100 are all inherently hard to bleed, but it must be done all the way to the top of the injectors.
When I rebuild or work on the fuel systems on these, i go through the extra effort to get all the air out.
If i replace the injectors or pumps, I will run fuel through them before i install them or parts attached to them.
Pete G
Jan 28, 2025
Cleveland, OH
I bled my way from the racor to the engine, then replaced the fuel filter and left it lightly attached, cranked and bled that, then moved up to the bleed valve. Another boat owner (same boat) tried to bleed it, as well, before I replaced the pump. I'll take another pass through it all.
