Hello, I have a Grasshopper zero turn with D722 that started running out of fuel in the filter between the lift and injection pump and of course would stall or die at that point. I replaced the lift pump with a factory replacement with no help. I then installed a low pressure electric, also no help. What I did notice was when the electric pump was turned on it started sending fuel through the return to the tank before the motor was started. The return comes off the front injector. I went back to the mechanical lift pump, restricted the flow of the return and had no more problems, filter stays full. Seems it's bypassing too much fuel ? Why ? Thanks in advance !
