D1703 rebuild
rentthis
1,007
24
38
summerville,sc
I am into the start of this thing and hit a small snag. The WSW says that when connecting the rod to the piston to immerse the piston in 186 degree oil for 15 min. before inserting the wrist pin. Does this have to do with making the wrist pin installation a slip and slide deal and can this be done properly without the heated oil?
Jim L.
855
158
I believe that is to expand the hole, not for lubrication. Oil bath gives better and uniform heat transfer.
The other ways are local heating and using a press.
rentthis
1,007
24
38
summerville,sc
Thanks Jim, that confirms my suspicions. I have a press. Do you know if it is the same result either way? I really don't want to heat oil for one piston.
6,619
You can also put it in the oven at about 250F for 30 min to get it to expand it the right amount. ;)
Wear welding gloves to work with it.:eek::p:D
Jim L.
855
158
I think that if you sent it out, it would probably be put to the press after heating with a torch.
Without a press, I would heat it in the oven for a while, and cold soak the pin in a baggie in the freezer. Then move fast to mate it.
Wolfman just posted...
rentthis
1,007
24
38
summerville,sc
I have a good plan, thanks to you fellows, on the wrist pin. I got to thinking (finally) is it ok to press in the wrist pin bushing or should I do the heat/cool thing there as well? I pressed it out before asking the pros. Dammit.
Thanks, Mike
Jim L.
855
158
The bushing should go in easier because it can give in the center where there is no metal.
If it is hard to get in, then heat the bigger part.
If the pin is hard to get in, then heat both the rod and the bushing with the bushing installed - and chill the pin.
When you heat it in the oven, everything expands, including the holes.
