G garrettohio Member Equipment Kubota L2900 Sep 16, 2023 41 0 6 Ohio Jun 5, 2024 #1 On the L2900 specs it says that it has D1503 engine and that bore is 84 mm.on all the pistons I seen for D1503 was 83 mm pistons . Is 83 mm piston correct size and the rings take up rest of bore diameter to make it 84 mm?
85Hokie Moderator Staff member Lifetime Member Equipment BX-25D ,PTB. Under Armor, '90&'92-B7100HST's, '06 BX1850 FEL Jul 13, 2013 10,512 2,285 113 Bedford - VA Jun 5, 2024 #2 Info I see is 83 mm
85Hokie Moderator Staff member Lifetime Member Equipment BX-25D ,PTB. Under Armor, '90&'92-B7100HST's, '06 BX1850 FEL Jul 13, 2013 10,512 2,285 113 Bedford - VA Jun 5, 2024 #4 Ok - someone (not us) has got some wrong info posted on the net...... this is straight from a Kubota website : ( I hope this is correct! ) Piston diameter: Reactions: 1 user
G garrettohio Member Equipment Kubota L2900 Sep 16, 2023 41 0 6 Ohio Jun 5, 2024 #5 85Hokie said: Ok - someone (not us) has got some wrong info posted on the net...... this is straight from a Kubota website : ( I hope this is correct! ) Piston diameter: View attachment 130091 View attachment 130090 Click to expand... Yeah all the ones I seen was 83mm.except for the oversized one with cylinders bored.dont take much to confuse me.lol
