D1105 question
I smell smoke
Zd28
Oct 20, 2023
Jacksonville fl
I have a d1105 engine that has cylinder damage. I found a d1105t engine near me online. My question is the d1105 and the d1105t the same short blocks? Any help would be appreciated
CAPT Seabee
Grand L5460
Dec 28, 2022
72
68
Bonners Ferry ID
pigdoc
G1800S L2500
Aug 19, 2022
279
209
SE Pennsylvania
Often, learning the architecture of obsolete Kubota engines can be challenging.
In general, all Kubota Turbo engines will be Direct Injection, with the injectors centered on the bowls in the piston tops. Non-turbo Kubota engines are usually Indirect Injection, with the injectors delivering fuel to a small spherical pre-ignition cavity that opens into the combustion chamber. And, no bowls in the piston tops.
If you look at the gasket surface of an IDI head, the port from the pre-ignition chamber is readily visible, and you won't see any place where an injector could be placed to deliver fuel directly to the combustion chamber.
It seems likely that crank and rods could be interchangeable between engines with the same bore and stroke. Does anyone know if you can put bowled pistons and a DI head in/on a non-turbo short block without complex machine work? I kinda doubt it...
-Paul
