D1105 fuel bleed screw
kubota guy1265
Kubota D1105
Mar 17, 2023
Pennsylvania
Hey I have a D1105 that I’ve been messing around for a while now to get running and just somehow broke off the bleed screw that connects to the inlet of the pump. Anyone know where I can order a new one? I can’t seem to find it anywhere. Thanks
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
3,107
1,708
WestTn/NoMs
Not sure if this is what you’re talking about. Broke off of this.
Looks like it left something behind in that banjo bolt. You may need a new banjo bolt too if you can't clean that one up.
I think I gave the wrong # the first time
Bleed screw 70000-65203
Banjo bolt 70000-65202
Copper washers 15221-96650
These are parts for a Kubota L2050 tractor, which uses a version of that engine.
FYI, some Kubota tractors have a jet valve instead of the screw. But it has a return hose that connects with the injector return hoses, which I don't see on yours. Saves some mess when priming the injector pump.
kubota guy1265
Kubota D1105
Mar 17, 2023
Pennsylvania
Alright i’ll look into it. Thanks a lot
