Coupler Needed
wmurf
L235 4wd
Aug 8, 2011
Milton, FL
I own a Kubota L235 (4WD) that has a splined shaft protruding from the front of the engine that is being used to drive a front-mounted hydraulic pump for a loader (pump & loader after-market). The coupler attaching (over) this splinned shaft is worn out & the previous owner drilled & tapped a couple of holes in it & inserted cap screws to attach it to the engine shaft.
The hydraulic pump is also worn out & I’ve got to replace it. I’d like to replace the shaft, coupler, etc. powering it as well (fix it all correctly all at once). So far I can’t find a source for a coupler to fit the splined shaft coming out of the front of the engine.
I’m a new tractor owner (presently regretting buying this one) so any advice or suggestions are appreciated.
wmurf
L235 4wd
Aug 8, 2011
Milton, FL
LT1Pat,
That's what I thought too, but I'm not having any luck so far at the local Tractor Supply Store or the local Kubota dealers. Spline measures (w/ calipers) .92 inches and I'm not finding anything that small at Tracor Supply.
wmurf
L235 4wd
Aug 8, 2011
Milton, FL
Thanks! This is very helpful. Any idea where I can find some of the parts shown? For whatever reason, I can make out the part numbers on the 2nd page. Thanks again.
Babyfat
111
Grass Lake, MI
www.dakins.com
The L1730 loader is Kubota so any dealer should be able to help you if not you could give us a call 517-784-3146 we are a dealer in Michigan
John
