cost for a tune up B7100 hst
lablover
b7100
Sep 10, 2013
omaha, ne
I am not very good with machines and I have a leak in what I think is the plastic gas tank. So while I have the B7100 hst looked at for the leak I want a tune up as well (changing all fluids). What do you think would be a fair cost for a tune up?
5,899
I'm not real sure as I do all my own work, but just normal cost on fluids and filters would be about $200, and I would think $150 to $200 labor sounds about right.
Billdog350
Kubota L3710 HST,L2230A QT,forks,Takeuchi TB125, 60" Luck Now pto Snowblower
Jan 6, 2014
468
East Hampton, CT
I'm not sure about the older B7100's but the newer kubota's have a "kit" for the filters which include all the hydraulic, air, oil and fuel needed for your machine. They run about 100-200 depending on model. For the B7100 you'll need another 3-4 quarts of good diesel oil (approx $20). UDT will be the most expensive stuff. Tractor supply sells some stuff that is RATED to be the same as Kubota UDT, and it smells the same, so I think on a machine that old you'd be fine to run it. I believe that stuff is about $60 for 5 gal so you'll have it a while and several changes.
All in, you'll be at about $200-300 for fluids and filters. And your machine will be good for another 100hrs.
