Concerned about LX2610 after sitting
Fred2233
Oregon
My brother has only been able to use his LX2610 for about 30 minutes over the past 16 months and that 30 minutes was on one specific day. It started right up back in November and ran with no issues but we are concerned about the diesel. It is stored indoors where it is 55-65 degrees year round.
I have read posts where people have mentioned untreated diesel going bad in a short period of time. We are not diesel guys so we don't know if bad diesel is something that can be visually seen? Can we shine a light into the tank to check? If so, what exactly are we looking for? Would it be a good idea to pump out the tank and start fresh?
Is there anything else that should be checked after it sitting for so long?
Thanks
10,264
Your fine, the likelihood if it going bad is very low under those circumstances.
If your worried about it get a cetane booster and a biocide to treat the fuel.
4,766
Although being stored in a climate controlled area is good, I would respectfully add that you should consider keeping it topped off as well.
Empty, or nearly empty tanks, that sit for long periods can invite water from condensation.
My theory is that a full tank lessens the amount of humid air in the tank, thus eliminating/lessening the chances of water in your fuel. (y)
BX23-S,57 A-C D-14,
6,101
Why gamble ? That diesel fuel is at least 16 months old. Sounds like it wasn't 'treated'. it doesn't cost that much to drain the tank, install a new filter or two, refill with fresh fuel. If the old fuel 'looks good', add it to the fresh, say 10-25% at a time when you fillup. At least your diesel is cheap ! I'm paying $6.60 US$ per USG this week, going to get higher too .
Depending on the hours of the machine, might want to consider replacing the engine oil.
