J Jeff Gordon New member Equipment B7100hst,loaderb1630-c Jul 18, 2015 97 0 0 Oxford,Michigan May 29, 2016 #1 Does anyone know the compression of a b8200 hst,engine tag#d950-a-d-t,also if you know what the intake and exhaust clearance is?
D Diydave New member Equipment L2202 tractor, L185f tractor Oct 31, 2013 1,635 11 0 Gambrills, MD USA May 29, 2016 #2 Don'y have the manual, so I don't know for sure, But 10 thou, should get you started, on the clearance
85Hokie Moderator Staff member Lifetime Member Equipment BX-25D ,PTB. Under Armor, '90&'92-B7100HST's, '06 BX1850 FEL Jul 13, 2013 10,790 2,600 113 Bedford - VA May 29, 2016 #3 Jeff Gordon said: Does anyone know the compression of a b8200 hst,engine tag#d950-a-d-t,also if you know what the intake and exhaust clearance is? Click to expand... intake and exhaust should be set to 8 thousand cold 450 psi is standard , low limit is 325 psi
J Jeff Gordon New member Equipment B7100hst,loaderb1630-c Jul 18, 2015 97 0 0 Oxford,Michigan May 29, 2016 #4 85Hokie said: intake and exhaust should be set to 8 thousand cold 450 psi is standard , low limit is 325 psi Click to expand... thanks very much,it's for my son trying to get this tractor going!
