Comparable
Luperjosh
26
Ofallon, Missouri
Hello,
I need to know if 1977 kubota b6000 2wd parts are compatable with 4x4 parts and body.
I own the 4x4
theee is a 2wd close to me for sale. Works needs battery but mine has a lot of sentamental value, (been in the family awhile type thing)
Thank you for reading
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,242
1,025
Williamstown Ontario Canada
Hello,
I own the 4x4
I do not know the answer to your question but suggest you advise on the transmissions of both machines
Dave
6,934
Yes everything except the front axle is the same.
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,242
1,025
What do you mean advise the transmissions? Look at the serial numbers see if they match?
What I meant was does one have an HST while the other is a standard transmission.
Like I said I do not know the B6000 but on the B7100 the HST model has a longer frame.
NIW's answer is all you need!!
Dave
kubotafreak
Sep 20, 2018
1,049
394
Arkansas, US
Buy it as a parts tractor, fix it, and then you have two tractors...
