Code n-0093
ihrigrenee
Kubota M5-111
Dec 14, 2024
Mississippi
When it first started it was acting like a short in wires cause if she hit a bump it threw it. Now it comes up and the tractor acts like. It wants to die but doesn't when it happens the gas pedal doesn't respond to acceleration at all .i could. Kill it and restart it and it run fine until I hit anuno again and have ti kill it to fet it to do right. Now it's coming on everytime I engage my tiller and I have to kill it about 5 or more times and the error is not wandering to gi away. Before this happened some watered down disel was put in it the alarm came on i drained the water seperator and then it got worse about coming on adyer that
5,038
curious... googled, found this...
That code basically means low fuel pressures been detected or a system leak. If the fault code came back it means there is an actual problem detected or what is called an active fault. You could have a problem with the pressure sensor in that circuit or wiring. You could also have an actual fuel pressure problem.Apr 18, 2019
query, did you TOTALLY remove all the 'watered diesel' out of the tank ? If not, I would and replace all fuel filters. You 'might' have damaged the 'pressure' sensor the google hit talks about...
pretty sure someone who knows that machine will reply....
