Clutch smell
kbhblazer
L 4400
Jul 17, 2012
Mount Pleasant ,Tx
I am new to the forum. I have an L4400 4x4 front end loader. It hasd 160hrs on it. I let a freind use the tractor and since I have gotten it back, I get a smell of a clutch every now and then. I have always made a point not to ride the cLutch and the adjustment is good.The tractor does not show any sign of slipping or anything. Should I be concerned and start saving some money up to have the cluch fixed.
GWD
M7040, L48 TLB, BX2200
Jan 8, 2010
792
17
Northern California
With 160 hours on it there should be warranty coverage. They will not cover abuse unfortunately. It wouldn't hurt to ask your dealer to look at it.
The clutch or flywheel may have developed a "hot spot" that is rubbing because of warping. That could have been caused by operator error and/or excessive heat.
Does the odor come when the clutch is fully engaged (slight slipping)? Or is it when it is being engaged (warped/high spot)? When it is fully disengaged there should not be any odor unless it is badly out of adjustment.
If you have a two-stage clutch that runs the PTO then does the odor come when the PTO is engaged? How about when the clutch is partially depressed to disengage the PTO?
Lots of question, I know, but just trying to figure out the "now and then" timing.
Anyway, hindsight about loaning your tractor may be a learning experience. It may not be related to the problem but certainly causes suspicions.
Bluegill
Jan 11, 2012
1,559
Success Missouri
I can't see it needing a clutch with only 160 hours, but stranger things have happened when loaning out equipment...
3,152
I think we found your problem:
Burned clutch smell is by no means normal, so it doesn't look good. Perhaps you'll get lucky with the warranty.
kbhblazer
L 4400
Jul 17, 2012
Mount Pleasant ,Tx
Thanks for replying. I havent been able to get on the web sight for the last couple of days. No it doesnt seen worse when the PTO is in service .It doesnt slip at all. I dont think the warranty will be an option, it an 2005 model year.Sounds like Im screwed.
avi8tor
L2800DT, BX2380, RTV X900
Mar 14, 2010
101
Cleveland, Alabama
I have a 2010 L2800DT with 200 hours on it. I started to get similar smell usually when I stop and get off after running it for a couple of hours. It only started after replacing the hydraulic fluid and filters with fresh Kubota hydraulic fluid.
