Hi Guys,
This is a continuation, of my questions here: http://www.orangetractortalks.com/forums/showthread.php?t=19106
I've only had my BX1870 for a few weeks... but from day one... I've been thinking about leaf collection for this coming fall. When I bought it... the quote on the factory PTO bagger was CRAZY !! Even though it is more compact that a cyclone rake... it was significantly more $$$. Because of that... I put it on the back burner... UNTIL.......
Local to me, I found a complete Ingersoll HydraBagger. (cheap) The guy who I bought it from said he didn't use it much, and I believe it. The bags are in good shape... the impeller is not beat up... heck, even the orange pant is clean. (FYI, it's a match for the Kubota orange) I even received the Ingersoll mounting and boot for the deck. It's not a match for my Kubota deck... but I'm sure I can get it to work. Oh, and fab'ing up a mount shouldn't be too hard.
Now... my tractor doesn't have any rear hydro... but after making my post above, and looking over the parts explosion for the BX25 (with a backhoe) I found that they just split off the FEL/3 point pressure, and there is a second drain on the side of the trans. So, I ordered a few fittings from Discount Hydraulics, and I should be able to get it hooked up.
If anyone has any info on the hydro motor... please let me know. right now... I'm not sure what to do with a motor control. The tractor this came from has more flow... but I'm not sure of the "Split" of the Ingersoll system. So... I'm going to get it rigged up, and check the RPM. I'm hopping the output will work without needing a valve. But if I do... I may just put a bypass, on a dial, and bleed off pressure, and return it like a "Power Beyond" system.
Here's a few pics to get things going. AND as a final FYI... I'm hoping to have this all done for well under $400.
