Charging
skipper1
Front loader and back hoe
Sep 27, 2026
12
Ireland
I have only recently Purchased a b7200 hst 4wd. The charging light started glowing after 2 days so I charged it. Then went the same again 2 days later So I bought a new battery 2 days later it started glowing again. I found a bad connection at battery terminal and cleaned it. Checked with multimeter and it was pushing 13.85v. today I hooked up the headlights through loom and original switch. I went to start it and glow plug indicator didn't get warm and she wouldn't start. Any idea what's wrong please
3,166
Sounds like you have a problem with the charging and/or wiring. Was the battery dead when it wouldn’t crank?
I would disconnect the headlight wiring at the switch and see if that helps the battery stay charged. I guess you could also just disconnect the negative battery cable to see if that helps first then try to narrow it down. They also make disconnect devices for the battery if you wanted to install that for testing.
skipper1
Sep 27, 2026
12
Ireland
The battery was good. I will disconnect the lights tomorrow
skipper1
Sep 27, 2026
12
Ireland
Thanks
Thanks bud. I.ll do that tomorrow
jaxs
B1750HST
Jun 22, 2023
1,113
836
It could be something minor or it could be something major, then it might be a combination. Only way to find out is with a multimeter or hire someone to find it for you.
