and make sure your front wheels are straight!Just back up slightly (inches), and it will drop in or out with no resistance.
Mine had 42 hours on it now…. Stock everything. Had the shift out of 4wd from day one…Tire pressures all good? According to the owners manual. People with used tractors, are your tires stock size?
Yours is an odd case for sure.Mine had 42 hours on it now…. Stock everything. Had the shift out of 4wd from day one…
Try doing what I do for it…. stop, crank the steering all the way to the right stop, pull against it a bit, then push down on the 4wd control.. drops out every time..My mx5100 is hard to shift out from the brand new get go. Usually have to lift the front wheels with the FEL. Hate to force it.
When your tires spin without it.Why on the topic of 4WD my newbe question is when do I generally use it??? I would assume when using the FEL or the grappler. Thanks in advance!
