Changing Fuel Filter on B7510
scottbennet
29
Natick, MA
Hello. I bought a used B7510 and it's now time to change the fuel filter. The manual says how to physically change the filer (loosen plastic bowl, replace element, reassemble). And then it says you need to bleed system. For bleeding the manual says to fill the fuel tank w/ diesel and then start the engine and run for 30 seconds. Does anybody know how this works. I've had other diesels and bleeding involves opening a valve and pumping. Any help would be great. Thanks in advance.
lsmurphy
B7001
Oct 19, 2012
1,197
Parrrottsville TN
Shut off fuel.
Remove bowl.
Replace filter.
Thread ring partially.
Turn on fuel and allow it to fill bowl, shut off fuel.
Start tractor.
Turn on fuel.
Allow fuel to spill over the top of the bowl, tighten ring.
Run tractor at half throttle for several minutes to cycle fuel through line.
Thats how I do it without bleeding system.
2,645
Shut off fuel.
Remove bowl.
Replace filter.
Start tractor.
Turn on fuel.
Me too, on my B7100.
