change?
hodge
Nov 19, 2010
2,903
450
Love, VA
Wow, that is a clean, low hour tractor to be in the 20 year old range!
I guess you will get a lot of opinions, so I will only offer mine- I'm not an expert.
While I believe in maintenance, I don't change something just because of age. If it still works, and doesn't show signs of giving out, I keep using it. If it were my tractor, and the oil in the axle and transmission look clean, don't show contaminants like water or other floaties, and it doesn't smell burnt, I would keep using it. Again, that is just my opinion.
I would never do this to my equipment, but an elderly neighbor who passed away about 6 months ago had an 86 Honda Foreman 350 ATV. This old gentleman could break an anvil- he abused everything he owned. That atv still runs strong, and he never changed the oil in it. It still has the factory oil. Maybe that's Honda for you, or maybe oils hold up longer than we give them credit. I believe that in this case, it's a little bit of both.
Welcome to OTT, by the way!
live_roll
M108 / BX 25 / RTV 900 / ZD331 / M7060 / B1200 Mx5100 Ford 1500
Dec 16, 2009
53
Irricana Alberta
WOW!! that is one meticulous looking tractor ! It looks like it just rolled off of the showroom floor!! Gorgeous!!
Cheers
Roger
freewheel3
MX5000DT LA852, BX1800D, B6000DT, B6200HSTD, B7100HSTD, L185, T1700HX, ZD1211
Mar 9, 2013
334
Alberta
If it was mine, I'd service it. Start fresh. It might cost a $100 but its worth it. Its mint, try to make that last. IMHO.
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
Richmond Va
GEEZ take that thing out of the shed and let it breath some! Put some hours on that thing and work it! Diesels do not like to sit and actually rot worse then if you run them.
spd122
mooresville, NC, USA
I am going to change it my friends all say its a waste. but I do the oil twice a year so its about time I did the other oils too. thanks for the nice comments and advice. Ben
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,440
78
Rocky Face, Georgia
Just for piece of mind I would change the fluid out. As nice as your tractor is why not go ahead and spend a few extra dollars to help insure it's done right.
