Chain Size
molon labe
Hoosick Falls NY USA
I"m trying to find the length and width of chains that will fit on 15 x 19.5 R4 Tires. I previously posted this question asking for the length and width directly but to answer this question the chains would have to off the tractor and laying flat on the ground. With chains on the tires, can someone measure the length of the chain going from side to side across the tire tread and the diameter of the circle the chain makes on the side of the tire? Any help would be appreciated.
Blue2Orange
BX2380 with LA344S & QH05. SB1051. SG0554. BB1248. RB0560, Vassar dirt bucket
Apr 3, 2025
367
257
Bayview Township
Purchasing new? I purchased chains from tirechain.com. They have a size selector tool. Just checked to see if there are any dimensions listed for your 15x19.5s. No luck.
Have R4s on the SCUT. Tiny wheels at IIRC 26x12. 2 link ladder model. Personally would not go with the 4 link design even with larger tires. Guessing 4 link ladders would slip more and be a bumpier ride plus less traction. I'm even 2nd guessing myself going with the 2 link v. diamond pattern. Next set maybe.
10,397
It would help if you gave the real tire size as I doubt you have a 15" inch tall tire on a 19.5" rim.
DONLI
L3301,FL, MUSTANG 2054 SKID STEER, 6FT HYD. SNOW BLOWER,and other things of labo
Jul 28, 2025
99
86
duluth mn
15X19.5 is not a 15 tall tire its a 15 wide tire mounted on a 19.5 rim!!
Don
10,397
My apologies, I'll blame it on not enough coffee! šŸ˜ž
