Carplay Front/Rear Dashcam in Cab
Old Machinist
Kubota LX3310 cab, JD4410, JD F725, Swisher 60", etc.
May 27, 2024
723
842
NE FL
Another camera thread. This is not an endorsement because it is untested beyond initial install and impressions.
I picked up one of those Carplay/Android Auto dash cams off marketplace for fifty bucks. I've been wanting to put something in my little Kubota cab and this looks ideal. It is 4" high by 10" wide. Doesn't take up much space on the dash ands doesn't' obstruct my view out the windshield. It is supposedly up to 4K front and 1080P rear. Default it was set to 2K front and I just left it at that. This one is branded Cinandrow but I don't see any for sale anywhere and an email to their service address asking for a user manual went unanswered. I've seen similar units advertised for $70 to $140.
The front camera can be raised or lowered and also rotates. I won't be using anything but the rear camera view but it has loop recording of front and rear. It came with a 64gb sd card installed. That is a nice feature if you encounter any wildlife you want to look back at. It also has dual bluetooth 5.0 but I don't anticipate using that feature either. I use my phone and 3M headphones for hearing protection and music.
My crummy cell phone pics don't do it justice. The image is crystal clear. I haven't even driven the tractor with it so I hope it doesn't vibrate but I don't expect that it will.
I had to make a bracket to screw the rear camera onto and both the camera and display are mounted with double stick adhesive.
Sidekick
Jul 29, 2023
1,304
1,905
N.Y,
I just put a wireless setup on my tractor and the camera can be moved anywhere within 300 feet of the display. Really nice for the forks and rear snowblower with the magnetic camera mount and solar recharging of the camera. Tractors should come standard with them.
Old Machinist
May 27, 2024
723
842
NE FL
I have some wireless cameras. I could probably mirror link the app for one of those through this display?
Donystoy
Dec 10, 2013
743
384
Binbrook, Ontario
I still have to hook up the camera that I got last fall. Just a suction cup screen mount to the side door with the camera mounted under the cab so I can see the position of the stump grinder. I just installed an oil cooler for the pto driven hydraulic system that I put on the BH77 so I will do the fan control at the same time.
