Caroni Finish Mower
scattergun
Kubota 2008 B2320, Kubota 2014 RTV 1140
Jul 25, 2017
37
Troy,MI
Anyone have any experience with this brand finish mower? Good~Bad or otherwise!!
6,981
They are some of the best made equipment out there.
scattergun
Jul 25, 2017
37
Troy,MI
Thanks might have a opportunity to pick one up that is used but in good shape.
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
2,185
1,316
Near Lancaster, PA, USA
I have one that I bought new around 1991. It is a 5 foot side discharge that has been abused badly, welded back together a time or two, sat outside for most of its life and should be dead. It lives and gets used on occasion behind the Ford 1210. I have a 6 foot LandPride rear discharge for the Kubota that works well but have been toying with the idea of getting a Caroni 93 inch rear discharge.
Utopia Texas
Kubota B2650/Kubota L6060
Jun 14, 2017
110
Brookshire & Cat Spring, Texas
I have the largest Caroni Estate Mower which has 5 blades and is 93" wide. Great mower but 2 minor problems.
(1) After two seasons and just 30 hours on the mower the wheels started to peel rubber and one wheel came completely apart. This is on smooth ground and I always grease the bearings before each use. The mower is always washed off and stored inside out of the sunlight. The rubber compound does not impress me.
(2) I wish the wheels could be adjusted higher. 4" may sound plenty high but on my 8 Acres of Burmuda during hot dry weather this is too short. 6" would be my preferred height most of the time
